imported_eric_h
- Mar 14, 2007
- Atlanta, GA
Asking 500 bucks for everything.
I have a Brown and Sharpe No2 Light mill for sale. Wife says it has to go so my loss is your gain. It has some broken handles and needs some clean up but when i bought it i made sure all the power feeds work in its 3 axis. It has the A and B arbor supports and it has a universal head. There are also several pieces of 30 taper camlock tool holders.
In full transparency the vertical head is disassembled as u will see in the pictures. I had taken it apart to replace bearings and do some general cleaning and thats when i noticed there were some gear alignment issues. All the pieces are there per the diagram but the shims(#3038 in diagram) that someone had put in there are incorrect and proper shims would need to be made and fitted. I have pictures of the gear teeth so u can see their condition. I also had purchased some of the main bearings that go in the mill head but they are not installed. My price for everything is 500 dollars which is def. less than what i have in the mill but i want it to go to a good home and I know there is some work with that mill head that needs to be done. I have the mill in a garage. I have a pallet jack so i could help load it into a drop deck trailer if that was used. Please let me know if u have any questions and if u need more pictures. I think i can only post 10 here but have several more of the head and other areas of the mill.
I am located about 26 miles north of Atlanta, GA.
thanks for looking.
6784380142 is the cell
thanks for looking.
