Pete Deal
- Apr 10, 2007
- Morgantown, WV
Can you just make a new one?
I am under the impression that he is going to cut past the bend.The problem with all these drilling ideas is the well is bent 15 degrees. Any drill and guide will need a a flex shaft to go around the bend.
Bill D.
Figuring loctite at 3000 psi shear strength gives about 2300 lbs of pull on 1" joint length. If the tc is .03 wall the ultimate tensile strength will be around 1800 lbs assuming 316SS. At least those numbers are favourable.Maybe a tool to deburr the end, then a steel sleeve to slide over the tube snug. If you could get an inch of snug fit, strong locktite with primer would get a good grip on the tube.
I was allEven with such a thorough description I am having trouble picturing the entire scenario.
I like peters idea as well. I would start there.
I would think hand drilling is going to give sub optimal results. Could you modify a drill press of mag drill to at least give you some consistent feeds if you insist on going the drilling route?
Good luck with whatever you end up trying next.
I was all for that method but the internal temps are still 400 deg. Any grease or sealant would likely just fall right out quick. The probe is actually drilling quite nicely but it appears that the well has a slight bend to it so it slowed down. Another day or two of cooling may allow us to use the hydraulic method.Why not tried the hydraulic methode first It would not have prevented other methods If filled properly a couple of inch overlapping the thermocouple would be enough
Peter
Notice
